Re: Timing the engine with new mags
norbert J. Mc Luckie
Post by norbert J. Mc Luckie »
'I, recently, had my mags rebuilt and it is time to install them on my Ranger 440-C
My A&P thinks that we have to remove the prop in order to do the timing to the engine.
I don't want to do that unless it is absolutely necessary. What is the opinion of you experts, in the field? This is on a 1938 short-nosed F-24.
Norbert "Lucky" Mc Luckie 815 472 2523 Momence, Illinois. cell 305 942 7066
norbymac20@sbcglobal.net
Lucky
Michael Denest
Post by Michael Denest »
'Have your mechanic read the overhaul manual on mag timing.  Do not remove the prop.
Quando omni flunkus moritati
- "Red" Green
----- Original Message ----
Sent: Wednesday, August 13, 2008 3:24:56 PM
Subject: [fairchildclub] Timing the engine with new mags
norbymac20@sbcgloba l.net
Lucky
'Mike We did read the manual and it talks about a timing wheel. My AP doesn't have one and we intend to borrow one. How do we mount it?
Lucky
Sent: Wednesday, August 13, 2008 3:31 PM
Subject: Re: [fairchildclub] Timing the engine with new mags
- "Red" Green
Lucky
Bob Haas
Post by Bob Haas »
'Better get another A&P. Read the Ranger Manual, first.
_____
On Behalf Of Norbert J. Mc Luckie
Sent: Wednesday, August 13, 2008 3:25 PM
440-C
the engine.
Lucky
Bob Haas
Post by Bob Haas »
'NO No No No. Read the proper Manual!
_____
Sent: Wednesday, August 13, 2008 4:28 PM
Lucky
prop.
- "Red" Green
440-C
the engine.
Lucky
Mike Danielle
Post by Mike Danielle »
'Norbert,
If you can find TDC on the back jug, you can time the mags using a degree
wheel on the spinner. Or, just use a TimeRight if you can get your hands on
one. I recommend the TimeRight but you have to use it on the front cylinder
because the tool interferes with the No. 2 cylinder fins. When the No 1 in
TDC is on the compression stroke, the No 6 is TDC on the exhaust stroke.
You have to keep this in mind and go another 360 degrees to do the timing
properly. If your mech can't figure this out, he ain't much of a mech.
I don't know of anyone who has one of the original factory degree tools that
used the arrow that's cast on the front of the case. But you can get dead
nuts on with any tool that finds TDC and the TimeRight is the best.
You don't have to remove the prop.
Ranger Mike
Sent: Wednesday, August 13, 2008 12:24 PM
> my Ranger 440-C
> to the engine.
> 305 942 7066
> Lucky
Michael Denest
'Aircraft Tool Supply has timing wheels and the Time Rite.  It mounts on the prop, align the wheel with TDC of #1 cylinder compression stroke.
http://www.aircraft-tool.com/shop/search_result.aspx?PageNo=1&PageSize=-1
http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=E25&ReturnPage=/shop/search_result.aspx?PageNo=1
- "Red" Green
Sent: Wednesday, August 13, 2008 4:28:14 PM
Lucky
- "Red" Green
Lucky
Jack Threadgill
Post by Jack Threadgill »
'I have used one of the new electronic levels. Set TDC for #1. Attach the
level to the prop hub. I used duct tape. Press the "Zero" button on the
level and then rotate to the desired number of degrees BTDC. Mine called
for 22 degrees.
Jack
Jack Threadgill
1602 Brook Hollow Dr
Bryan, TX 77802
979-779-7155
threadgl@suddenlink.net
On Behalf Of Michael Denest
Sent: Wednesday, August 13, 2008 7:33 PM
http://www.aircraft
http://www.aircraft
x?PageNo=1
- "Red" Green
Lucky
prop.
- "Red" Green
440-C
the engine.
Lucky
ranger440c5
Post by ranger440c5 »
'Can someone who has responded to this subject explain to me their
reluctance to removing a prop? Is it because they have an Aeromatic?
I too dreaded removing my prop (Ranger W/ Warner hub+ Sensennich
86AB54)...until I noticed some "smoking" at hub/prop junction. Upon
removal, it was discovered (not related to original reason for
removal) that the rear cone was in the advanced stages of galling.
Nearly threatening the hub's integrity. Hub was not loose nor was
nut. I found it no issue to remove prop/hub assemby and made it a
personal inspection point at every other annual. I wouldn't think it
is a "set it and forget it" Ronco cooker. Probably because the
short splined Warner and Rangers use no front cone and if the forward
bronze bushing is worn the hub can walk around (galling the rear
cone) without experiencing a loss of nut torque. Having witnessed
this, if I was McLucky's mechanic and I never saw that prop off, I
would be inclined to remove it as well.
As for finding the "crank time", it has never failed to be spot on
and repeatable to use a dead stop through a plug hole to find BDC and
set the degree wheel accordingly.
--- In fairchildclub@yahoogroups.com, "Mike Danielle"
> Norbert,
degree
hands on
cylinder
No 1 in
stroke.
timing
mech.
tools that
get dead
> Ranger Mike
> From: "Norbert J. Mc Luckie"
them on
> > my Ranger 440-C
timing
> > to the engine.
is the
nosed F-24.
Illinois. cell
> > 305 942 7066
> > norbymac20@...
> > Lucky
> > Yahoo! Groups Links
Jack Threadgill
'I am new to Ranger ownership. Would you please describe the prop removal
procedure that you used.
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
On Behalf Of ranger440c5
Sent: Saturday, August 16, 2008 11:33 AM
Subject: [fairchildclub] Re: Timing the engine with new mags
> Norbert,
degree
hands on
cylinder
No 1 in
stroke.
timing
mech.
tools that
get dead
> Ranger Mike
them on
> > my Ranger 440-C
timing
> > to the engine.
is the
nosed F-24.
Illinois. cell
> > 305 942 7066
> > norbymac20@...
> > Lucky
> > Yahoo! Groups Links
