'The outside of the the rear seat, trim turnbuckle housing is rubbing
on the inside of the fabric, causing the fabric to stress and
eventually tear. The fabric has been repaired twice but unless I
prevent the rubbing it will tear again. Does anyone else have this
problem and if so, how did you solve it?
524JM'
Re: question
Re: question
'My only experience is with 1946 models. Apparently, yours must be an earlier model.
Sent: Monday, July 07, 2008 7:01 AM
Subject: [fairchildclub] question
524JM
Re: question
'Hey Tom I still have my PT too. I just checked the clearance and
it is quite adequate front and rear of the repeater crank
Assembly. Mine is located by a metal tab welded to the longeron and the
crank is fastened to it . You will have to fabricate a stand off
Piece to correct the lack of clearance. I would suggest a small block of
wood fiber classed and painted to match. You remember
How parts were cut to fit and painted to match for type certificates. Bob
Haas Buckingham AAFB.
On Behalf Of Buhwana
Sent: Monday, July 07, 2008 10:01 AM
524JM
524JM
Re: question
'Maybe I missed something here are we talking PT or F 24 ? Bob
Haas
524JM
Haas
524JM
