'I centered both mag indexs prior to pulling the mags and did not move
 the prop .  After mag overhaul, I restabbed and it worked well for the
 right but not Quite correct with the left.  I would like to find out
 how to verify the engine is at 25 degress BTDC and try and stab the
 left mag again. I do not see any Index marks on the Crank.  I guess
 thats what I am asking.  Aside from the index mark on the mags. How
 can I verify 25 BTDC..
 Michael'
						Re: Bob Dunn timing question
				Tom Downey
'Manufacture a piston stop that will fit the spark plug hole (I used
and old spark plug and a 1/2" rod) Place the piston stop in the spark
plug hole while the engine is at bottom dead center on #1 compression
stroke. Attach a degree wheel to the prop shaft?prop and set at any
position, carefully turn the engine in the direction of rotation,
until the piston stop is touching the piston. mark the degree wheel at
that position. rotate the engine backwards until the piston stop is
touching the piston again, mark the degree wheel again. TDC is half
way between your 2 marks. on the side of the degree wheel that you
have not turned the engine.
rotate the degree wheel on the shaft until TDC is indicated by the
degree wheel pointer, lock it down and rotate the engine backwards
until 25 degrees is indicated. stab the mag at "point opening" for #1
plug.
--- In fairchildclub@yahoogroups.com, "michaelmps"
plug.
move>
the> the prop . After mag overhaul, I restabbed and it worked well for
'> right but not Quite correct with the left. I would like to find out
> Michael
				rangerrobertmn
'Tom,
We do it exactly like you do, but instead of a 'degree wheel', we use
an electronic 'smart level' taped to the prop. When at TDC, we set
the level to ZERO, then turn the prop 'til it reads 25. Old eyes can
read inch high digits, easier than 'tiny' marks on a 'degree wheel'.
Also, someone should have mentioned the unique 'rubber ring' between
the mag and the mag-drive is really a 'vernier' adjuster. It adjusts
in 2/3 degree increments. It seems that you rotate it about 15
degrees in order for it to mesh with the mag-drive, but all that
effort resulted in 2/3 degree change. Very frustrating until you
figure out what is happening, but very precise. I wish all mags were
like that.
1939 Fairchild 24 K
Sky Harbor airpark
Webster, MN
--- In fairchildclub@yahoogroups.com, "Tom Downey"
like that.
1939 Fairchild 24 K
Sky Harbor airpark
Webster, MN
spark>
compression> plug hole while the engine is at bottom dead center on #1
at> stroke. Attach a degree wheel to the prop shaft?prop and set at any
#1> that position. rotate the engine backwards until the piston stop is
for> plug.
> move
out> the
the> > how to verify the engine is at 25 degress BTDC and try and stab
guess> > left mag again. I do not see any Index marks on the Crank. I
How> > thats what I am asking. Aside from the index mark on the mags.
'> > can I verify 25 BTDC..
> > Michael
'VERY GOOD! B.H.
_____
On Behalf Of rangerrobertmn
Sent: Wednesday, April 30, 2008 8:49 AM
Subject: [fairchildclub] Re: Bob Dunn timing question
Tom,
like that.
1939 Fairchild 24 K
Sky Harbor airpark
Webster, MN
						_____
Tom,
like that.
1939 Fairchild 24 K
Sky Harbor airpark
Webster, MN
spark>
yahoogroups.com, "michaelmps"> plug.
> move
out> the
[Non-text portions of this message have been removed]'> > can I verify 25 BTDC..
> > Michael
				Michael Denest
'I use a buzz box and Time Rite indicator.  Before I start mag timing, I check the mag points for the proper gap of .012" to .015".  Then I find the #1 cylinder compression stroke to set the card for TDC.  I then back the blade off then bump the prop in the direction of rotation and listen for the buzz box.  When I get the tone, I check the card to see where 25° BTDC is and adjust the coupling as necessary.  I do each mag individually then do a final check on both mags.  Takes me about 1 hour to do both mags.
ATS has the Time Rite available but it's several $$$$. If you do a lot of engines, it's a great investment.
Quando omni flunkus moritati
- "Red" Green
----- Original Message ----
Sent: Wednesday, April 30, 2008 8:48:45 AM
Tom,
like that.
1939 Fairchild 24 K
Sky Harbor airpark
Webster, MN
--- In fairchildclub@ yahoogroups. com, "Tom Downey"
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
- "Red" Green
Tom,
like that.
1939 Fairchild 24 K
Sky Harbor airpark
Webster, MN
spark>
for> plug.
> --- In fairchildclub@ yahoogroups. com, "michaelmps"
> move
out> the
____________________________________________________________________________________> > can I verify 25 BTDC..
> > Michael
'This is the proper way to set the mags oh the Ranger Engines,
works every time! Bob H.
_____
On Behalf Of Michael Denest
Sent: Wednesday, April 30, 2008 10:21 AM
Subject: Re: [fairchildclub] Re: Bob Dunn timing question
- "Red" Green
Tom,
like that.
1939 Fairchild 24 K
Sky Harbor airpark
Webster, MN
_____
- "Red" Green
Tom,
like that.
1939 Fairchild 24 K
Sky Harbor airpark
Webster, MN
spark>
for> plug.
> move
out> the
> > Michael
				michael Steiger
'That is what I did because it sounded logical with out timing marks and you say the same thing.  Great!  I did it and all checks well. Thanks for all the help!  Everyone is great on thes site!  I hope I can help someone oneday.
Bob Haas wrote: This is the proper way to set the mags oh the Ranger Engines,
_____
- "Red" Green
Tom,
like that.
1939 Fairchild 24 K
Sky Harbor airpark
Webster, MN
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
_____
- "Red" Green
Tom,
like that.
1939 Fairchild 24 K
Sky Harbor airpark
Webster, MN
spark>
for> plug.
> move
out> the
> > Michael
				Michael Kelly
'Ther is a timing mark but you have to take the prop and nose bowl off.It is an arrow cast into the front case under the prop shaft.
Keep 'Em Flying1
Mike Kelly
Windows Live SkyDrive lets you share files with faraway friends.
http://www.windowslive.com/skydrive/ove ... ive_052008'
						Keep 'Em Flying1
Mike Kelly
_________________________________________________________________> To: fairchildclub@yahoogroups.com
> From: michaelmps@yahoo.com
> Date: Sat, 10 May 2008 16:33:38 -0700
> Subject: RE: [fairchildclub] Re: Bob Dunn timing question
> _____
> Mike
> - "Red" Green
> From: rangerrobertmn
> yahoo.com>
> Tom,
> like that.
> Bob Waldron
> 1939 Fairchild 24 K
> Sky Harbor airpark
> Webster, MN
> spark
> compression
> at
> #1
>> plug.
>> move
> for
>> the
> out
> the
> guess
> How
>>> Michael
