'Hey, I want to check the timing on the mags of a buddys PT-19.   He
 has the 200 hp 440.   The 3 manuals he has for the pland have no info
 on how to do this.  What manual is available or can anyone scan the
 info??
 Cheers, Michael'
						Re: Ranger timing
Re: Ranger timing
'It's 25 degrees BTC. You can use #6 for BTC. Line up
the white, beveled mag gear with the pointer in the
window, stab the mag & check with timer. Adjustment
made by rotating the rubber coupler, being careful not
to turn the mag gear when re stabbing. Chances are you
won't be able to hit 25 exactly. Just get as close as
possible. Any other questions, let me know.
Bob Dunn
--- michaelmps wrote:
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ'
Bob Dunn
____________________________________________________________________________________> Hey, I want to check the timing on the mags of a
> buddys PT-19. He
> pland have no info
> anyone scan the
> info??
> Cheers, Michael
Re: Ranger timing
'You need the Ranger overhaul manual for the information.  You will not find it in the AAF manuals.
Quando omni flunkus moritati
- "Red" Green
----- Original Message ----
Sent: Tuesday, April 29, 2008 1:18:53 AM
Subject: [fairchildclub] Ranger timing
info??
Cheers, Michael
- "Red" Green
info??
Cheers, Michael
				michael Steiger
Re: Ranger timing
'I centered both mag indexs prior to pulling the mags and did not move the prop .  After mag overhaul, I restabbed and it worked well for the right but not Quite correct with the left.  I would like to find out how to verify the engine is at 25 degress BTDC and try and stab the left mag again. I do not see any Index marks on the Crank.  I guess thats what I am asking.  Aside from the index mark on the mags. How can I verify 25 BTDC.
BOB DUNN wrote: It's 25 degrees BTC. You can use #6 for BTC. Line up
Bob Dunn
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
Bob Dunn
> buddys PT-19. He
> pland have no info
> anyone scan the
> info??
> Cheers, Michael
				michael Steiger
Re: Ranger timing
'Thanks!
Michael Denest wrote: You need the Ranger overhaul manual for the information. You will not find it in the AAF manuals.
- "Red" Green
info??
Cheers, Michael
- "Red" Green
info??
Cheers, Michael
Re: Ranger timing
'To verify the 25 deg. BTDC you'll either need a timing indicator disk or a Time Rite.  In both cases you'll reference off Top Dead Center(number 1 compression stroke).
Here's a good generic "how to time mags" guide.
www.avweb.com/news/maint/184370-1.html
Also, the procedure is shown in both the Ranger and Military overhaul manuals(at least the copies I've got).Curt Kinchenptcurt@msn.com
To: fairchildclub@yahoogroups.comFrom: michaelmps@yahoo.comDate: Tue, 29 Apr 2008 08:30:38 -0700Subject: Re: [fairchildclub] Ranger timing
I centered both mag indexs prior to pulling the mags and did not move the prop . After mag overhaul, I restabbed and it worked well for the right but not Quite correct with the left. I would like to find out how to verify the engine is at 25 degress BTDC and try and stab the left mag again. I do not see any Index marks on the Crank. I guess thats what I am asking. Aside from the index mark on the mags. How can I verify 25 BTDC.BOB DUNN wrote: It's 25 degrees BTC. You can use #6 for BTC. Line upthe white, beveled mag gear with the pointer in thewindow, stab the mag & check with timer. Adjustmentmade by rotating the rubber coupler, being careful notto turn the mag gear when re stabbing. Chances are youwon't be able to hit 25 exactly. Just get as close aspossible. Any other questions, let me know.Bob Dunn--- michaelmps wrote:> Hey, I want to check the timing on the mags of a> buddys PT-19. He > has the 200 hp 440. The 3 manuals he has for the> pland have no info > on how to do this. What manual is available or can> anyone scan the > info?? > > Cheers, Michael> > __________________________________________________________Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ---------------------------------Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.[Non-text portions of this message have been removed]
