'I have a 3/4" NPT plug on the top-rear left-hand corner of my cam box
(on the top) that I'm considering using for the return line for a
separator. I don't know what that tap was originally used for but,
since this is an experimental installation, would this be a good
location for the return line? What are other folks using?
Mike'
Re: oil-air separator
'Mike, I used a fitting on the side of intake cam cover to return
the condensed oil fumes. Be sure
It line goes into a non pressure area in the cam boxes. There should be
enough height in the line to keep
The separator dry. If the separator is located above or on the same plane
as the oil pump your will be ok.
Bob Haas NC 81236.
On Behalf Of Michael Danielle
Sent: Tuesday, December 25, 2007 2:48 AM
Subject: [fairchildclub] oil-air separator
Bob Haas NC 81236.
'Mike,
Get a copy of the PT-26 parts breakdown which will show you how it is put together.
Quando omni flunkus moritati
- "Red" Green
----- Original Message ----
Sent: Tuesday, December 25, 2007 2:47:58 AM
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
- "Red" Green
Mike Danielle
'Hi Bob,
I think what you're saying is the "intake" side of the cam box. That's the
one I'm talking about. However, I didn't know there ware ANY part of the
cam box that was pressurized. I believe the entire cam box cavity is
drained by the scavange pump. Not so?
Sent: Tuesday, December 25, 2007 8:29 AM
Subject: RE: [fairchildclub] oil-air separator
> return
> Bob Haas NC 81236.
> _____
> Mike
'Yes! You have the idea .
On Behalf Of Mike Danielle
Sent: Tuesday, December 25, 2007 3:44 PM
Subject: Re: [fairchildclub] oil-air separator
Hi Bob,
Hi Bob,
> return
> Bob Haas NC 81236.
> _____
yahoogroups.com]
> To: fairchildclub@
yahoogroups.com
> Mike
