far. If you haven't bought the Stits covering video yet I think it is
the best help. Also I think the guy that is probably the most
knowledgeable about Poly Fiber is Norm Douthit-I think he was with Ray
Stits form the begiining. I call him when I have a problem of questions
and he always is very helpful. He also sells the Poly Fiber products.His
phone no. is 1-888-811-2232. I don't want to try to sound like an old
expert because I'm not----well mabey the old part is true but if you
haven't used Poly Fiber before you might cover something small first
like an aileron.I's really not hard to do but something small might be
good practice before the big ole fuselage.Good luck and if you can
please send me a picture when you have the fuselage looking good.
See Ya,
Buell
james chybicki wrote:
> Hi Buell
> That is great info!
> Did you cover the F24 yet?
> Was there any tricky areas when applying the poly
> fiber we should be careful with?
> Jim
> --- Buell Powell wrote:
> > Hi Jim,
> > On most of my projects I use Poly Tone on the
> > fabric and
> > Aerothane for everything else. I did use Aerothane
> > on the fabric wings
> > on a Cessna 120. and am using it on everything on
> > the Fairchild. I have
> > used Aerothane fully flattened on a Cub inst panel
> > and it works really
> > well. The Poly Tone is easy to use but doesn't have
> > a shine. The
> > Aerothane is a little tricky because if you aren't
> > careful it will
> > run(sometimes it wont run when you are spraying it
> > but will soon after.
> > and you need a good paint gun and an HVLP gun
> > doesn't work very well for
> > it. One thing to remember is to give it plenty of
> > time between coats (I
> > usually wait 30 minuets and then press my thumb on
> > some over sprayed
> > object. If it comes off on your thumb you need to
> > wait. Hope this helps.
> > Buell
> > > Hi Buell
> > > We haven't made up our mind on that yet. The Poly
> > Rep.
> > > is pushing us toward Aerothane with a flatner
> > agent to
> > > match the WW2 paint scheme, have you ever used
> > > Aerothane?
> > > How is your F24 coming along?
> > > Jim
> > > --- Buell Powell > > wrote:
> > > > Hi Jim,
> > > > Are you going to use Aerothane or Poly Tone
> > > > paint.
> > > > Buell
> > > > > Hi Guys-
> > > > > Our Fuselage fabric will be here at the end of
> > the
> > > > > week!
> > > > > Please advise any critical or tricky areas we
> > > > should
> > > > > keep a look out for!
> > > > > We decided to use the PolyFiber System.
> > > > > Any Comments would be appreciated.
> > > > > Jim Chybicki
> > > > > UC-61K 43-14964/HB- 690
> > > > > ____________ _________ _________ _________
> > > > > Be a better Heartthrob. Get better
> > relationship
> > > > answers from someone
> > > > > who knows. Yahoo! Answers - Check it out.
> > > > > http://answers. yahoo.com/ dir/?link=
> > list&sid=
> > > > 396545433
> > > > 396545433
> > > Yahoo! oneSearch: Finally, mobile search
> > > that gives answers, not web links.
> > > http://mobile. yahoo.com/ mobileweb/ onesearch?
> > refer=1ONXIC
> ____________ _________ _________ _________ _________ _________ _
> Sick sense of humor? Visit Yahoo! TV's
> Comedy with an Edge to see what's on, when.
> http://tv.yahoo. com/collections/ 222
