'Does anybody know which cylinder normally runs hottest?
Remko'
Re: hottest cylinder ranger
'Remko,
#5 is the hottest. 2nd cyl back. Also make sure your installation has the additional bump on the inside, left side. This creates a higher pressure to direct air across the #5 cylinder.
Jamie Treat
Jamie Treat
'Thanks Jamie.
Is there a drawing for this 'bump'somewhere on the cd?
My airbox hasn't got it,so I want to install one.
Regards,
Remko
Regards,
Remko
has the additional bump on the inside, left side. This creates a>
> Remko,
> Jamie Treat
'Remko,
I have never seen a drawing, only know about it for experience. The Denest's may be able to shed some light from the Ranger side, most likley from the PT side of the house. I bet it started with the Mil.
Sent: Thursday, June 21, 2007 2:02 PM
Subject: [fairchildclub] Re: hottest cylinder ranger
Thanks Jamie.
Regards,
Remko
> Remko,
> Jamie Treat
'Remko,
The "bumps" are a strip of aluminum that is attached to the access door of the Ranger airbox. If you don't have this, you need to find a door with the bumps. This is standard on all Ranger installations as a way to force cooling air through the cylinders. Send me a picture of what you have.
Quando omni flunkus moritati
- "Red" Green
Sent: Thursday, June 21, 2007 11:21:26 PM
Subject: Re: [fairchildclub] Re: hottest cylinder ranger
Remko,
- "Red" Green
Remko,
Thanks Jamie.
Regards,
Remko
> Remko,
> Jamie Treat
No need to miss a message. Get email on-the-go
with Yahoo! Mail for Mobile. Get started.
http://mobile.yahoo.com/mail
'Mike,
The access door of the airbox is just straight from front till back.
nothing attached to it.
Over here in Europe it will be impossible to find another door.If
this really improves cooling,I will have to make it myself I guess.
If I could get some dimensions and a drawing,this should be possible
I hope.
Or is there someone out there who has a lead to finding the right
access door?
Remko
likley from the PT side of the house. I bet it started with the Mil.'
I hope.
access door?
Remko
door of the Ranger airbox. If you don't have this, you need to find> Remko,
Denest's may be able to shed some light from the Ranger side, most>
> Mike
> - "Red" Green
> From: Jamie Treat
> Remko,
'Remko,
Did you get the two pictures I have sent to your e-mail adress this
morning? It will answer most of your questions.
I can measure the details and send them to you.
Karl
UC-61K HB-ERO
Karl
UC-61K HB-ERO
'--- In fairchildclub@yahoogroups.com, "m51rs" wrote:
> Mike,
possible
> I hope.
> access door?
> Thanks,
> Remko
> > Remko,
access
find
installations
> > Mike
> > - "Red" Green
> > From: Jamie Treat
> > Remko,
The
'Hello Karl,
Unfortunately nothing showed up.
Try my mailaddress rs(ad)sijben.nl
By the way is your home-base close to Geneva?
Regards,
Remko
Remko,
Regards,
Remko
Remko,
> Karl
> UC-61K HB-ERO
