'Hi to all,
The sump on the PT-19 fuel tanks show signs of leakage.
They are stained all over along with the tank in that area.
Has anyone ran into the sumps being porous allowing fuel to seep through.
John'
Re: fuel tank sump
Michael Denest
Re: fuel tank sump
'The best thing to do is to drain the tanks, remove the sumps, clean the mounting bases, install new gaskets and reseal all the joints and fittings with a joint compound (no plumbers tape!). Be aware that due to age, some or most of the hardware will be very cranky. Be careful of using heat guns around fuel vapors!!!!!!!!!!!!!!
Quando omni flunkus moritati
- "Red" Green
----- Original Message ----
Sent: Monday, January 29, 2007 9:24:51 AM
Subject: [fairchildclub] fuel tank sump
Hi to all,
John
Do You Yahoo!?
http://mail.yahoo.com
- "Red" Green
Hi to all,
John
Do You Yahoo!?
Re: fuel tank sump
'Just went through the same thing Mike, has the fix. Bob Haas ,
N46199.
_____
On Behalf Of John Ellis
Sent: Monday, January 29, 2007 9:25 AM
Hi to all,
John
N46199.
_____
Hi to all,
John
John Ellis
Re: fuel tank sump
'What type sealing compound works best for this? Thinking about using tite-seal.
John
John
Sent: Monday, January 29, 2007 9:33 AM
Subject: Re: [fairchildclub] fuel tank sump
- "Red" Green
Hi to all,
John
Do You Yahoo!?
Michael Denest
Re: fuel tank sump
'That should work.
Sent: Wednesday, January 31, 2007 9:49:27 AM
John
John
The best thing to do is to drain the tanks, remove the sumps, clean the mounting bases, install new gaskets and reseal all the joints and fittings with a joint compound (no plumbers tape!). Be aware that due to age, some or most of the hardware will be very cranky. Be careful of using heat guns around fuel vapors!!!!!! !!!!!!!!
- "Red" Green
Hi to all,
John
____________ _________ _________ _________ _________ __
Do You Yahoo!?
http://mail. yahoo.com
Have a burning question?
Go to www.Answers.yahoo.com and get answers from real people who know.
