Re: Improving takeoff and climb.
Bradley Bormuth
Post by Bradley Bormuth »
'Hello folks,
We have just completed the restoration on our 24W40; however, I must
say that the takeoff and climb I am getting leaves a lot to be
desired. I operate out of a 3000' grass strip with trees and power
lines on both ends and the takeoff (to me) seems a little too slow
(maybe even on the edge of unsafe).
The reason for posting this is I wanted to know what experiences you
guys have had in this area and anything I can do to improve my
performance. We have a Warner 165 with a Sensenich W86CA-67 fixed
pitch wood prop.
BTW, one thing in particular that I would like to know about is what
are your opnions about installing an Aeromatic prop in place of the
Sensenich?'
Steve Newing
Post by Steve Newing »
'Hi Brad,
Give us some number eg. airspeed, rpm, climb rate etc
Steve
Sent: Monday, August 21, 2006 11:38 AM
Subject: [fairchildclub] Improving takeoff and climb.
Hello folks,
pitch wood prop.
Sensenich?
Bob Haas
Post by Bob Haas »
'If you find an Aeromatic that is airworthy, you will never want a fixed
pitch prop again! Once you get it set up for your needs
It makes a new airplane. Jamie Treet might have a line one. Bob Haas.
On Behalf Of Steve Newing
Sent: Monday, August 21, 2006 6:02 AM
Subject: Re: [fairchildclub] Improving takeoff and climb.
Hi Brad,
Steve
Hello folks,
pitch wood prop.
Sensenich?
fchld
Post by fchld »
'Bradley,
If you can get a aeromatic it will improve the performance of the 165 Warner I believe Tarver propellers in fallon Nevada has started to make them again.
John berendt
Fairchild Club
Sent: Sunday, August 20, 2006 8:38 PM
Hello folks,
pitch wood prop.
Sensenich?
John Duncan
Post by John Duncan »
'A Curtiss Reed prop will definately improve your performance!
John Duncan
>From: "Steve Newing"
>To:
>Date: Mon, 21 Aug 2006 20:01:50 +1000
>Hi Brad,
>Steve
> From: Bradley Bormuth
> Hello folks,
> pitch wood prop.
> Sensenich?
ranger440c5
Post by ranger440c5 »
'What's the empty weight?
--- In fairchildclub@yahoogroups.com, "Bradley Bormuth"
> Hello folks,
must
power
you
> pitch wood prop.
what
the
> Sensenich?
Bradley Bormuth
'Hello all,
Thank you for your interest. In response to the questions about the
performance and other specifications about the plane, I have prepared
the following--but I can't remember the exact figures, so please take
that into account:
I will walk you through the takeoff procedure we do.
Add full power once aligned with the runway. The engine is turning
1850 rpm if I can remember correctly. Push the stick full forward
until the tail leaves the ground. Smoothly pull the stick back to
maintain a slightly tail high attitude while keeping the tail off the
ground. Once the plane lifts off (~1000 ft), keep in ground effect
until 70mph and climb out at 70mph (300-400fpm) until clear of the
trees (or other obsticle) then accelerate to 80mph (~500fpm) and
continue climbing. By this point, the engine is turning about 2000
rpm.
Here are a few numbers from the current configuration of the airplane:
Empty weight: 1797.98 lbs @ 19.82"
Warner 165 (R500-7)
Sensenich W86CA-67 fixed pitch wood prop
Thank you for your help
Brad
--- In fairchildclub@yahoogroups.com, "Steve Newing"
> Hi Brad,
> Steve
Chief Russell
Post by Chief Russell »
'What is your field elevation of your airport-? Density altitude affects
performance a great deal, including jets, but more especially our older
limited powered airplanes. Don't try to force the airplane in the air as it
fly when it is ready, given everything else is normal, takeoff power, etc.,
she will fly.
Our Continental powered 24W is quite limited in the power department,
especially in the summer months in Kansas. However; it will fly when it is
ready; my partner is one of these "Git R done" pilots and is working on
gaining patience with our 1946 F24 when he is not in his 310D.
Proper pitch, length, etc., can be experimented with some and I am
inclined to get one of the wood props Jamie has suggested from the Dude in
Oklahoma to see if we can gain some climb performance. Wish the weather had
cooperated last weekend so I could have joined you other Fairchild folks in
Poplar Grove.
Fly safe
Dick Russell, N81229
[mailto:fairchildclub@yahoogroups.com]On Behalf Of ranger440c5
Sent: Tuesday, August 22, 2006 8:52 AM
Subject: [fairchildclub] Re: Improving takeoff and climb.
> Hello folks,
must
power
you
> pitch wood prop.
what
the
> Sensenich?
Bradley Bormuth
'Dick,
We have been flying out of an airport at 1020 feet MSL. I think the
issue may be with the prop. If i'm not mistaken we have a prop
pitched for cruise and that would be why we can't achieve full power
at takeoff (although 1850 rpm sounds very low even for that).
Brad.
--- In fairchildclub@yahoogroups.com, "Chief Russell"
affects
older
air as it
power, etc.,
> she will fly.
department,
when it is
working on
I am
Dude in
weather had
folks in
> Poplar Grove.
> Fly safe
Robert Webster
Post by Robert Webster »
'Brad,
The following is from the type certificate for the W-165. Item 108 refers
to a fixed pitch wood prop. If that is what you have it sounds like your
static RPM is in the ball park. That is if you are at 1850 prior to brake
release.
RRW
Propeller limits (With Item 108)
Landplane: Static rpm at maximum permissible throttle setting, not over
1925, not under 1825. No additional tolerance permitted.
Diameter: Not over 86 in., not under 83 in.
Sent: Wednesday, August 23, 2006 10:11 PM
> Dick,
> Brad.
> affects
> older
> air as it
> power, etc.,
>> she will fly.
> department,
> when it is
> working on
> I am
> Dude in
> weather had
> folks in
>> Poplar Grove.
>> Fly safe
> Internal Virus Database is out-of-date.
> Checked by AVG Free Edition.
> Version: 7.1.405 / Virus Database: 268.11.1/421 - Release Date: 8/16/2006
