Re: [Fairchild club] Falcon prop information
dcasali
Post by dcasali »
'I ordered a prop from Mike in late October. I last had an email from him
on 11/8/06, and all seemed well then. Haven't tried to reach him since.
Dan Casali
Jamie Treat wrote:
> All,
> Don't think that is a true story. He had some issues with the FAA and
> Fed Court. As in the recent past that was being worked out. He is
> currently making progress on a customers 24R46.
> Jamie
> ----- Original Message -----
> From: Chief Russell
> Sent: Monday, November 20, 2006 6:18 PM
> Subject: [fairchildclub] RE: [Fairchild club] Falcon prop information
> I just learned from the FAA that he is probably in jail - seems he and
> some
> cohorts have committed some crimes that involved the FBI-? I would like to
> have a wood prop for the F24...
> Dick
> Dick Russell, CMS, USAF (Retired)
> DNR Aviation, LLC (Home of the 2007 Meyers Owners Reunion)
> Checking Six and Flying safe in the OTW & F24
> Go Big Red
> visit www.councilofchiefs.org, www.russellaire.com
> -----Original Message-----
> From: fairchildclub@yahoogroups.com
> [mailto:fairchildclub@yahoogroups.com
> ]On Behalf Of Jamie S. Treat
> Sent: Sunday, February 19, 2006 6:20 PM
> Subject: Re: [fairchildclub] Falcon porp information
> Buell,
> Here is the contact info:
> Falcon Propeller: Mike Redpath. PO Box 678, Washington, OK 73093
> Cell: 405-414-1072
> Mike just used my prop as the first article conformance for his Production
> Cert.
> Jamie
> From: "Buell Powell"
> To: >
> Sent: Sunday, February 19, 2006 5:01 PM
> > Jamie,
> > Thanks-Do you have Mike's contact information?
> > Buell
> > From: "Jamie S. Treat" >
> > To: >
> > Sent: Sunday, February 19, 2006 5:46 PM
> >> Buell,
> >> Send it back to Falcon Props (Mike Redpath) I just got my new prop from
> >> Mike. Very nice prop. Makes the Sensench look sad.
> >> Jamie
> >> To: "Fairchildclub" >
> >> Sent: Sunday, February 19, 2006 3:44 PM
> >> Subject: [fairchildclub] Falcon porp information
> >>> I have a Falcon prop that I bought used. Does anyone know who I can
> >>> contact about refinishing it?
> >>> Buell Powell
> >>> [Non-text portions of this message have been removed]
> >>> Yahoo! Groups Links
> >> Yahoo! Groups Links
> > Yahoo! Groups Links
> SPONSORED LINKS Private plane Fairchild semiconductor Plane reservation
> Fairchild Jet plane Pedal plane
> YAHOO! GROUPS LINKS
> a.. Visit your group "fairchildclub" on the web.
> b.. To unsubscribe from this group, send an email to:
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
Dan Casali
MacWizard
Box 1286 Ketchum, ID 83340
208.726.5120
Post by Jamie Treat »
'All,
It mounts just fine:) Better than a Sensenich and allot nicer.
Mike was building them under one time article approval from the FAA. He used my prop during the building for his Prod Cert. Each prop that he built had to be certified by the FAA in person. Not a hard process, just very time consuming. Built to the specs of the Acft TC and the Prop TC.
Sent: Monday, November 20, 2006 8:25 PM
Subject: [fairchildclub] Re: [Fairchild club] Falcon prop information
Could some one explain how a "Falcon" propeller is mounted on F24R46?
Lets assume it meets TC #A-706. I would assume as he holds no TC
approval(as of Tdata 2006-20) that it gets done by the "gray area" on
A-706 under item #109....
"109. Propeller - wood (any fixed pitch wood propeller eligible
for the engine rpm and power, and which meet the diameter
and static rpm limits specified)"
In which case how does one prove the prop meets the power capacity of
the installation? If it were built to the TC it is approved, but as
he holds no current TC approval, how does one know it is built to the
TC? The static RPM and diameter limits are obvious enough but how
does one prove a propeller built to unknown standards is "eligible
for the engine rpm and power" without exhaustive, complicated, and
lengthy testing? Sounds ticklish......
--- In fairchildclub@yahoogroups.com, "Jamie Treat"
> All,
and Fed Court. As in the recent past that was being worked out. He is
> Jamie
> From: Chief Russell
information
he and some
would like to
> Dick
> Go Big Red
> [mailto:fairchildclub@yahoogroups.com]On Behalf Of Jamie S. Treat
> Buell,
> Cell: 405-414-1072
Production
> Cert.
> Jamie
dcasali
Post by dcasali »
'My understanding was Mike is using the prop designs developed by Ole
Fahlin of Fahlin Propellers.
Fahlin had contemporary designs for most aircraft from the mid-20's thru
the 40's. Here is a bit of info on Fahlin props that I found on the web:
http://www.modernwoodenpropellers.com/fahlin.htm
> , "Jamie Treat"
> wrote:
> > All,
> > Jamie
> > From: Chief Russell
> information
> he and some
> would like to
> > Dick
> > Go Big Red
> > Buell,
> > Cell: 405-414-1072
> Production
> > Cert.
> > Jamie
Dan Casali
MacWizard
208.726.5120
