LONG TIME NO HEAR!
OUR PLANE IS READY FOR COVERING THE FUSEALGE! LIFE
SLOWED OUR DEDICATED WORK TIMES ON OUR UC-61K. ANYWAY,
IF YOU HAVE ANY DETAIL PICTURES OF THE STRINGER THAT
RUNS JUST UNDER THE FLAP PULLEYS, ABOVE THE REAR
WINDOWS, AND THE PORT SIDE STRINGERS THAT FOLLOW THE
FRAME TILL IT ENDS, WE HAVE SOME THOUGHTS, AND SECOND
THOUGHTS, THEN THIRD... WOULD BE NICE TO SEE SOMEONE
ELSES SUPERB WORK!
THANKS
JIM CHYBIKCI
HB-690 / 43-14964
--- Buell Powell wrote:
__________________________________________________> Brad,
> The spars and tip bows were ok so I didn't
> replace them but I did
> make new ribs and leading edges. I have checked the
> wing tanks for fit and
> they line up very nicely. I think the reason some
> tanks end up too high is
> probably using too thick felt where the tanks rest
> on top of the ribs. I had
> planned on puting an original interior in mine but
> John Berendt called and
> has a turquois interior that he wasn't going to use
> and is sending it to me.
> I think if I paint the outside turquois & white it
> should look very
> nice.Thanks for the information about the rib
> stitching-& good luck covering
> the wings.
> Buell
> From: "windshieldguy2000"
> Sent: Monday, September 26, 2005 11:52 PM
> Subject: [fairchildclub] Re: Rudder pedel covering
> > Thanks for the post, Buell. I'm spending one more
> day in Oklahoma
> > working on my airplane, so it will likely be
> Wednesday before I get
> > you the name of the company that makes the diamond
> plate. Did you
> > build new wings for your airplane? The flap bays
> aren't difficult to
> > cover, but clearance between the bolt heads on the
> top surface of the
> > flaps and the flap bay is a little tight and will
> require lots of
> > trial fitting. You will also want to spend some
> time fitting your
> > fuel tanks before you cover. Mine fit really
> well, but I've seen
> > others that stuck up above the top surface of the
> wing (and into the
> > slipstream of that super-fast airplane) and they
> really took away
> > from the look of the wing.
> > If you look at the blueprints on the Fairchild
> CD-ROM, you'll notice
> > that the rib stitch spacing specifications
> subdivide the wing
> > cordwise into 3 sections of 22" each. The spacing
> (2 - 3 - 4" or 3 -
> > 4 - 5", depending on whether or not you're in the
> slipstream)
> > actually works out well using the 22"
> subdivisions. Stitching
> > between the ribs and the compression members is
> interesting, to say
> > the least, but all it takes is time.
> > If you haven't already found an interior shop, I
> HIGHLY reccomend
> > Interiors by Dene in the Oklahoma City area
> (forgot the name of the
> > podunk town, I'll get it when I find the name of
> the metal company).
> > Dene has all the original Fairchild patterns and
> did an outstanding
> > job on my airplane. Dene does quality work at
> very reasonable prices
> > in a relatively short amount of time, and he's a
> genuinely nice guy,
> > as well.
> > Hope all this helps. Good luck with your airplane
> and send me some
> > pics.
> > Best Wishes,
> > Brad Donner
> > NC77605
> > Yahoo! Groups Links
Do You Yahoo!?
http://mail.yahoo.com'
