'Hi....
installing the above,, referencing my Ranger OH manual and
illustration 410 unfortuanely cannot be read and I can't see the nut
installation sequence. any one out there help with this?
cheers
Mike'
Re: Camshaft housing cover nut installation sequence
Mike Bourget
Mike Danielle
'Mike
My manual is in the hangar. I'll retrieve it tomorrow and send the sequence
unless someone else beats me to it. Lots of little nuts...
Mike Danielle
Mike Danielle
Sent: Wednesday, February 23, 2005 6:08 PM
Subject: [fairchildclub] Camshaft housing cover nut installation sequence
> Hi....
> cheers
> Mike
Michael Denest
'Mike,
Starting in the center, snug down the nuts on each
side (do not final torque!) then work your way out to
the ends of the cover, alternating as you go. Then,
go back and torque the nuts using the same sequence.
--- Mike Bourget wrote:
Do you Yahoo!?
Yahoo! Mail - Easier than ever with enhanced search. Learn more.
http://info.mail.yahoo.com/mail_250'
__________________________________>
> Hi....
> manual and
> can't see the nut
> this?
> cheers
> Mike
Do you Yahoo!?
Mike Bourget
'thanks Mike... done... one stud is stripped.. so will have to
helicoil it and reistall the one stud
--- In fairchildclub@yahoogroups.com, Michael Denest
'> Mike,
> Mike
> > Hi....
> > manual and
> > can't see the nut
> > this?
> > cheers
> > Mike
> Do you Yahoo!?
Michael Denest
'Yeah, I forgot to mention that the cam box assembly is
brittle magnesium. Be careful installing that
helicoil, sometimes it can make matters worse! Have
you considered a high strength adhesive?
Do you Yahoo!?
Yahoo! Sports - Sign up for Fantasy Baseball.
http://baseball.fantasysports.yahoo.com/'
> will have to
> wrote:
> > Mike,
> to
> Then,
> sequence.
> > Mike
> > > Hi....
> > > manual and
> I
> > > can't see the nut
> with
> > > this?
> > > cheers
> > > Mike
> > Do you Yahoo!?
> search. Learn more.
Do you Yahoo!?
Mike Danielle
'Mike,
I have my manual and can scan and send the diagram if you need it.
Mike #3
Mike #3
Sent: Thursday, February 24, 2005 11:41 AM
Subject: [fairchildclub] Re: Camshaft housing cover nut installation
sequence
> wrote:
> > Mike,
> > Mike
> > > Hi....
> > > manual and
> > > can't see the nut
> > > this?
> > > cheers
> > > Mike
> > Do you Yahoo!?
Mike Bourget
'hmmm... its previously been helicoiled (it came off with the nut)
JB weld?
JB weld?
'> Yeah, I forgot to mention that the cam box assembly is
> Mike
> > will have to
> > wrote:
> > > Mike,
> > to
> > Then,
> > sequence.
> > > Mike
> > > > Hi....
> > > > manual and
> > I
> > > > can't see the nut
> > with
> > > > this?
> > > > cheers
> > > > Mike
> > > Do you Yahoo!?
> > search. Learn more.
> Do you Yahoo!?
Mike Bourget
'thanks Mike.. no need.. did it yesterday.
cheers
--- In fairchildclub@yahoogroups.com, "Mike Danielle"
cheers
installation> Mike,
> Mike #3
> From: "Mike Bourget"
> sequence
more.> > wrote:
> > > Mike,
> > > Mike
> > > > Hi....
> > > > manual and
> > > > can't see the nut
> > > > this?
> > > > cheers
> > > > Mike
> > > Do you Yahoo!?
'> > > http://info.mail.yahoo.com/mail_250
> > Yahoo! Groups Links
Michael Denest
'JB Weld to the rescue.
Do You Yahoo!?
http://mail.yahoo.com'
__________________________________________________>
> with the nut)
> JB weld?
> assembly is
> Have
> > Mike
> > > will have to
> Denest
> > > wrote:
> > > > Mike,
> each
> out
> > > to
> > > Then,
> > > sequence.
> > > > Mike
> > > > > Hi....
> OH
> > > > > manual and
> and
> > > I
> > > > > can't see the nut
> help
> > > with
> > > > > this?
> > > > > cheers
> > > > > Mike
> > > > Do you Yahoo!?
> > > search. Learn more.
> > Do you Yahoo!?
Do You Yahoo!?
