Re: Hayes brakes.
Re: Hayes brakes.
Post by Jamie S. Treat »
'Members,
I highly recommend that you clearly mark the Brake Master area and gear
struts with what type fluid is used.
Also recommend that you make a Oil Services List, put in the Log book where
it is noticable.
I continuly have to question customer aircraft (call the previous owner or
restorer) as to what the previous service was. It is hard to tell between
DOT 3, DOT 4, DOT 5, Motorcycle Strut Oil, and 5606 after it has been in
service, it becomes dirty and hard to tell the difference.
Sometimes I have to resort to the good ole taste test. That gets old.
Sent: Wednesday, August 17, 2005 5:02 AM
Subject: Re: [fairchildclub] Hayes brakes.
>I agree with Jamie. Use DOT 5 from the very
> beginning. Dot 5 is a synthetic fluid, DOT 3 is
> petroleum based. Did you also replace the seals in
> the master cylinder?
> Mike
> --- "Jamie S. Treat" wrote:
>> Bob,
>> The Dot 3 is too harsh, makes the rubber swell. I
>> use DOT 4 as the old
>> standard. Now I switch to DOT 5 with a flushed
>> system. Also the new
>> Clevelands will except the DOT 5 to my surprise.
>> Jamie
>> Jamie S. Treat A&P/IA
>> Aircraft Restoration & Repair
>> 24201 David C. Johnson Loop
>> Kelly Airpark
>> Elbert, CO 80106
>> HM/Shop 303-648-0130
>> JamieTreat@direcway.com
>> From: "Robert Etter"
>> To:
>> Sent: Tuesday, August 16, 2005 9:24 PM
>> Subject: [fairchildclub] Hayes brakes.
>> > To start with, about a year ago, I assembles two
>> brake assemblies for the
>> > 24 out of parts that I had on hand. Ordered new
>> pads for both assemblies
>> > (New Pads). Then turned down the pads to where
>> they met the .007-.010
>> > inch clearance with the drum. Serviced the
>> initially with Dot 3 brake
>> > fluid. Left side worked fine. I later found a
>> bad expander tube on the
>> > right side. Then things started getting messes.
>> Did much repainting on
>> > the lower right side. Took may parts apart and
>> repainted them. Ya hear
>> > that one before didn't ya.
>> > Finally got set up to start servicing the system
>> with Dot 5. I made a
>> > closed system to bleed the brakes and to same the
>> expensive Dot 5 fluid.
>> > Before I got started, I flushed the system and
>> lines with alcohol. After
>> > I got everything as clean as possible, I sued a
>> clear plastic hose coming
>> > from a bottle mounted up near the wing. I started
>> back-filling the system
>> > with fluid. Once I knew that I have fluid coming
>> up into the reservoir,
>> > and had got it topped off. A few good strokes of
>> the brake pedal showed
>> > that there was no air in the system.
>> > I tried to do the same thing on the left side.
>> I then noticed that the
>> > brake was dragging pretty hard. The brake
>> assembly was turned to match
>> > the brake drum over a year ago, and has done
>> noting but sit there until
>> > last weekend. I originally serviced it with Dot
>> 3, then about a month
>> > ago, bleed & flushed all that out with alcohol.
>> > Why should you come back a month later and find
>> the expander tube has
>> > swelled to the tune of .007"-.010". I had to
>> remove at least that much
>> > material to get the system to work right.
>> > Bob Etter
>> > PO Box 974
>> > Tonopah, NV 89049
>> > 775-482-6820
>> > rletter@citlink.net
>> > [Non-text portions of this message have been
>> removed]
>> > Yahoo! Groups Links
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
danMichael
Re: Hayes brakes.
Post by danMichael »
> owner or
> between
> in
Thats true dedication. What color is your tongue nowadays? :-)
:Dan
:NC81323 [DOT 3 / Dexron II ATF]'
Re: Hayes brakes.
'Blind from the chemical poisoning:). My wife just calls me the "Chemical
Man" when I come in from the shop.
Sent: Wednesday, August 17, 2005 6:50 PM
>> owner or
>> between
>> in
> :Dan
John Amundsen
Re: Hayes brakes.
Post by John Amundsen »
'What's it supposed to taste like? I have a plane without any records on the brake oil.
Sent: Wednesday, August 17, 2005 4:06 PM
Members,
it is noticable.
> Mike
>> Bob,
>> Jamie
>> Kelly Airpark
>> Elbert, CO 80106
>> To:
>> > Bob Etter
>> > PO Box 974
>> > Tonopah, NV 89049
>> > 775-482-6820
>> > rletter@citlink.net
>> removed]
>> > Yahoo! Groups Links
> Do You Yahoo!?
SPONSORED LINKS Plane Aviation Warner
Model planes Plane fare Plane tickets
YAHOO! GROUPS LINKS
Re: Hayes brakes.
Post by robert Etter »
'Regarding the internal parts of the Master cylinders, yes. They are all new
parts straight from NAPA. I still have one of the kits in the shop. I
destroyed one of the dust boots, and needed to buy another kit.
It really bothered me to see that the expander tube would be swelling up
after more than a year or so. It swelled enough to almost lock up that
wheel. I wonder if it had anything to do with the expander tube being out
of service for 30 years or more?
Bob Etter
PO Box 974
Tonopah, NV 89049
775-482-6820
rletter@citlink.net'
Re: Hayes brakes.
Post by Michael Denest »
'No. The type of fluid will affect it. Say for
example at some time, someone may have serviced the
brakes with 5606 hydraulic oil. Petroleum will ruin
the expander tube for sure. DOT 3 will do it also but
over a longer period of time when you don't notice it.
We replaced an expander tube for the same problem -
the DOT 3 got to the rubber causing the expander tube
to lock up the brake. We replaced the tube, the seals
in the master cylinder, flushed everything with
alcohol and reserviced with DOT 5. It's been fine
ever since.
> kits in the shop. I
> another kit.
> almost lock up that
> Bob Etter
> PO Box 974
> Tonopah, NV 89049
> 775-482-6820
> rletter@citlink.net
Do You Yahoo!?
http://mail.yahoo.com'
CarlMauro@aol.com
Re: Hayes brakes.
Post by CarlMauro@aol.com »
'Tastes like chicken.
Re: Hayes brakes.
'You will need to sample the old and the new and trust your taste buds. Other
wise flush and fill.
Sent: Wednesday, August 17, 2005 8:28 PM
> the brake oil.
> From: Jamie S. Treat
> Members,
> where
> it is noticable.
> or
> Jamie
> From: "Michael Denest"
> > Mike
> >> Bob,
> >> Jamie
> >> Kelly Airpark
> >> Elbert, CO 80106
> >> To:
> >> > Bob Etter
> >> > PO Box 974
> >> > Tonopah, NV 89049
> >> > 775-482-6820
> >> > rletter@citlink.net
> >> removed]
> >> > Yahoo! Groups Links
> > Do You Yahoo!?
> > Yahoo! Groups Links
> YAHOO! GROUPS LINKS
> Service.
John Amundsen
Re: Hayes brakes.
'Thanks for the respectful answer, unlike previous responder. Ha ha.
Sent: Thursday, August 18, 2005 6:42 PM
> the brake oil.
> Members,
> where
> it is noticable.
> or
> Jamie
> > Mike
> >> Bob,
> >> Jamie
> >> Kelly Airpark
> >> Elbert, CO 80106
> >> To:
> >> > Bob Etter
> >> > PO Box 974
> >> > Tonopah, NV 89049
> >> > 775-482-6820
> >> > rletter@citlink.net
> >> removed]
> >> > Yahoo! Groups Links
> > Do You Yahoo!?
> > Yahoo! Groups Links
> YAHOO! GROUPS LINKS
> Service.
YAHOO! GROUPS LINKS
Re: Hayes brakes.
'Does seasoning to taste help?
> Jamie
> From: "John Amundsen"
> > the brake oil.
> > Members,
> put in the Log book
> > where
> > it is noticable.
> > or
> difference.
> > Jamie
> > To:
> is
> seals in
> > > Mike
> wrote:
> > >> Bob,
> swell. I
> surprise.
> > >> Jamie
> > >> Kelly Airpark
> > >> Elbert, CO 80106
> > >> To:
> two
> new
> where
> found a
> messes.
> and
> system
> same the
> and
> sued a
> started
> coming
> strokes of
> side.
> Dot
> alcohol.
> and find
> to
> > >> > Bob Etter
> > >> > PO Box 974
> > >> > Tonopah, NV 89049
> > >> > 775-482-6820
> > >> > rletter@citlink.net
> > >> removed]
> > >> > Yahoo! Groups Links
> > > Do You Yahoo!?
> protection around
=== message truncated ===
Yahoo! Mail for Mobile
Take Yahoo! Mail with you! Check email on your mobile phone.
http://mobile.yahoo.com/learn/mail'
