'Anybody out there have a 24 with a Scott 3200 (or the like) on a
leaf spring mount? I've heard it done and am curious if a member here
has info (i.e. 337's). I searched the message archives and saw no
results.'
Re: Scott T/W
Re: Scott T/W
'Scott,
It was done one time in Switzerland it was not a very good installation.
There are not 337's in the states for the conversion.
Fairchild Club
Fairchild Club
Sent: Monday, November 29, 2004 8:34 PM
Subject: [fairchildclub] Scott T/W
> results.
Re: Scott T/W
'Paul,
Well stated. Also the Waco owners have converted to the 3200 and leaf
springs. They end up replacing the springs due to sag and also modify the
3200 with a locking device to prevent shimmy. The last 1930 WACO ASO
destroyed a right wing returning from Bartlesville. The empty weight at the
three point is between 250 and 300lbs. Then add fuel, pilot & passengers and
the weight can hit an easy 450-500lbs. That is a lot of weight on a
tailspring.
Lesson here, stick with the org manf equipment.
tailspring.
Sent: Tuesday, November 30, 2004 10:38 AM
Subject: Sv: Re: [fairchildclub] Scott T/W
> Hi
> When I started the resturation of my UC61A it had a Scott 3200
> installation with leaf springs. It was the uggliest thing in the world. My
> plane lost it´s original strut when landing on a frozen lake and hit a
> small ridge.
> The installation was made here in Sweden but I do not have a drawing for
> it.
> The installation is twice the weight of the original strut. The spring has
> to take about 420 pounds at it´s maximum. The steering cables has to be
> rerouted and the weight is about 40 pounds.
> I whould not have this weight so far back.
> paul
>> Från: "John Berendt"
>> Datum: 2004/11/30 Tue PM 01:34:25 CET
>> Till:
>> Ämne: Re: [fairchildclub] Scott T/W
>> Scott,
>> John Berendt
>> Fairchild Club
>> From: "ranger440c5"
>> To:
>> > results.
>> > Yahoo! Groups Links
>> Yahoo! Groups Links
> WebMail från Tele2 http://www.tele2.se
