Sent: Thursday, March 21, 2002 1:44 PM
Subject: [fairchildclub] Re: PT-19B Electrical system
> The Pierson Gen Terminals are marked GRD, FLD and ARM. The GRD
> terminal has on brush and field lead connected to it,the ARM terminal
> has one brush lead connected to it and the FLD terminal has one field
> lead connected to it. I believe from what you said before that this
> is a type "B" circuit? I took it over to a auto electic shop and they
> spun it up. They said it worked perfectly. Looks like new inside the
> unit. Data plate and arrows mark this unit as left hand rotation. So
> now all I need is a GCU. I e-mailed Zeftronics sales three days ago
> but still no reply.
> Thane Riffle
> --- In fairchildclub@y..., "ranger440c5" wrote:
> > Thane,
> > Not sure about the Pierson item. How are the terminals marked? F+
> A+
> > A-? How many are there 2 or 3? Check the brush that has the field
> > tied to it for continuity to frame with a multimeter. While your'e
> > at it spin the little bugger about 800 rpm in the direction you
> want
> > it to turn and check voltage across the 2 brushes +to+,-to-. If
> > voltage is developed positive, rotation is correct and residual
> > magnetism is still present. If neg voltage developed(a minus sign
> on
> > digital meter, a left side deflection on analog meter) rotation
> > incorrect. No voltage may signify loss of residual magnetism,
> fields
> > need flashing.
> > The Eclipse you have is a good little gen. Not sure if worth
> > rebuilding especially since you might have a usable alternative. It
> > is a type 1235. 30V 15A square head on flange with a 1" dia.cooling
> > spout on brush end, and has a nice rubber coupling inside the drive
> > end. Should have a directional arrow on the bearing cap on the
> brush
> > end frame(don't trust it). This unit should have only 2 brushes
> other
> > wise very similar to 309 type including terminal box on brush
> > endframe with terminal studs marked A-,A+,&F+. Which tells you that
> > it's type B circuit as the regulator will be supplying the power to
> > the fields.The one drawback is it must be force cooled. most others
> > are self cooled.
> > There are a couple shops that know these units and they are
> > available. Let's hear what you come up with.
> > --- In fairchildclub@y..., "pt19b2001" wrote:
> > > Looks like this one is a type "B" one of the brush leads and one
> > of
> > > the field leads are connected together to a terminal marked
> ground
> > > and this lead appears to be attached to the generator frame. The
> > > manufacturer of this generator is Pierson Electrical &
> Engineering
> > > Corp. type 2411 28.5V 15A still has sticker on it from Kelly AFB.
> > > Which is were my plane was based. I also have a bendix-Eclipse
> 28V
> > > generator. But no type # on it only MFG's DWG# 112180-1235-1. In
> > the
> > > PT erection and maintance manual it talks about type 1235
> generator
> > > installed in the PT-19B. I think thay meant drawing # but not
> > shure.
> > > the one I have looks like it was sitting in water. I think it
> will
> > > need a rewind. I have never seen another one of of this type,
> wish
> > I
> > > could find one. You would think they would be all over the place.
> > but
> > > that does not appear to be the case.
> > > Thanks for the help
> > > Thane Riffle
