'All,
What Mike says and more. The FAA hates the conversion of Cert aircraft to Exp.
Its a little more in depth. It is true an A&P can perform the Condition Inspection (Like and Annual), no need for an IA. The owner can assist and do certain preventive Maint items IAW FARs. If you the owner want to modify the airframe or engine that will effect airworthy factors, your AW cert is null and void. You will be required to go back to FAA or hire a DAR and or a DER to start the paperwork all over again. You may be required to fly a restricted flight time. And a DER starts at around $500.00 bucks and goes up. I wish I could make that kind of money filling out 337s.
This brings up the insurance issue. Most Insurance companies have restrictions, 25 hour and so on. So you may not have insurance for the first few hours, your risk. Also most companies will charge more for Exp aircraft. I had a Pitts Special for years and did I pay out the butt.
Also keep in mind you can build any part as the owner for your Fairchild. You duplicate that part via by comparsion or by eng data. You the owner will cert that part. But keep in mind, never tell the FAA you made the part better than the orginal, you will then be required to show how, what and why. Here comes the DER task. You build the part equal to the existing part, period....In addition, you the owner will be required to build the part with your hands or have someone build it for you, but you will be required to be envolved with the design and fab process. You will be required to prove that to the FAA. I, as an IA (its a fine line) cannot build a part from scratch and sell it to you as a cert part. The FAA rules have been rewritten and I believe much better. At one time I had a problem with the FAA in regard to Aeronca spars. They would not let me fabricate new spares out of new aircraft quality stock and return to service. I had to prove to them the the aircraft grade wood was in fact equal to the orgin
al manuf wood. Prove that by old Aeronca engineering data, stress and test data. I could not, therefore we ended up repairing the new spares. We took a small piece of old spar, glued and laminated it at the tip. Prepared an FAA form reflecting a repair. So what we ended up with was a new spar with a one inch splice at the tip near the bow. What a goat rope. Now you have to look at the Bogus parts issue. Technically, I can not go purchase a part from John Doe, will say a F-24 Hor Stab that has been sitting in his barn for 50 years. I know that it belongs to the F-24, it is in excellant shape and it would work better than the old rotten one on the existing airplane. But as an IA I have to show traceablity of that part in order to return it to service. I must show that that part is the correct part verified by P/N which will match the eng data. Now! the owner can purchase that part, hand it to me and tell me to install it. The owner in fact is certifying that part meets the above criteria.
What fun!
Jamie Treat'
Re: Expermintal Airworthiness certificate
'You too...don't add too much to the "empty weight" on Thursday! Happy
Turkey day!
Scott
Michael Denest wrote:
Scott
Building RV-4
Gotta Fly or Gonna Die!'
Turkey day!
Scott
> --- Scott wrote:
> > Hi Mike,
> > Actually I was responding to someone who has an
> > Experimental F24 and
> > wants to return it to standard category. Being that
> > it is already
> > experimental, I was just saying that I personally
> > would be interested in
> > an experimental F24. I would never go through
> > making a certified
> > anything into an experimental something. I am
> > building an RV-4 and own
> > a Corben at present. I don't have an experimental
> > just to get out of
> > annual inspections...I have to have a condition
> > inspection every 12
> > months like everyone else. I like the latitude to
> > be able to add or
> > subtract partsThe only thing I don't like about
> > 337's is the cost
> > of the IA filling out the paperwork and the FAA
> > having to approve it.
> > Experimentals bypass these two stages of
> > bureaucracy. I didn't take
> > your post as sarcastic at all. Good healthy
> > conversation cleanses the
> > soul
> Hey! Not a problem! I've had that situation where
> someone wanted to put a C-172 into the experimental
> category just so he could get it into the air quicker.
> I explained to him just how much bull he had to go
> through and then there was no guarantee that FAA would
> bless it. He saw the error of his ways and went
> through the process of obtaining a normal category
> airworthiness certificate. Happy flying and have a
> good holiday.
> Mike
> __________________________________________________
> Do You Yahoo!?
> Yahoo! GeoCities - quick and easy web site hosting, just $8.95/month.
> http://geocities.yahoo.com/ps/info1
Scott
Building RV-4
'Ya, tell me dealing with bureaucrats isn't like peeing up a rope
I
used to have an Aeronca and now an experimental Corben. Most days I
revel in the joy of the experimental versus certified. I remember the
big AD that was proposed for the 7 and 11 series back in 1998 for the
spars. Don't know if it was mandated, but I sold mine before I'd have
had do go Chapter 7, 11 and 13 bankruptcy. Now I don't worry about no
stinkin AD's
Seriously, I fly anything that has 2 wings, preferably 4!
Scott
PS Jamie...better to pay insurance out the butt than to take it UP the
butt without! I can't really talk to loud...I can't afford the
insurance on my Corben, so I'm real careful where I fly (over da trees
so all I have to do is buy some logs iffen I make it)
jstreat360@aol.com wrote:
Scott
Building RV-4
stinkin AD's
Scott
wood was in fact equal to the orgin>
> All,
> Also keep in mind you can build any part as the owner for your Fairchild. You duplicate that part via by comparsion or by eng data. You the owner will cert that part. But keep in mind, never tell the FAA you made the part better than the orginal, you will then be required to show how, what and why. Here comes the DER task. You build the part equal to the existing part, period....In addition, you the owner will be required to build the part with your hands or have someone build it for you, but you will be required to be envolved with the design and fab process. You will be required to prove that to the FAA. I, as an IA (its a fine line) cannot build a part from scratch and sell it to you as a cert part. The FAA rules have been rewritten and I believe much better. At one time I had a problem with the FAA in regard to Aeronca spars. They would not let me fabricate new spares out of new aircraft quality stock and return to service. I had to prove to them the the aircraft grade!
bove criteria.> al manuf wood. Prove that by old Aeronca engineering data, stress and test data. I could not, therefore we ended up repairing the new spares. We took a small piece of old spar, glued and laminated it at the tip. Prepared an FAA form reflecting a repair. So what we ended up with was a new spar with a one inch splice at the tip near the bow. What a goat rope. Now you have to look at the Bogus parts issue. Technically, I can not go purchase a part from John Doe, will say a F-24 Hor Stab that has been sitting in his barn for 50 years. I know that it belongs to the F-24, it is in excellant shape and it would work better than the old rotten one on the existing airplane. But as an IA I have to show traceablity of that part in order to return it to service. I must show that that part is the correct part verified by P/N which will match the eng data. Now! the owner can purchase that part, hand it to me and tell me to install it. The owner in fact is certifying that part meets the a!
> What fun!
> Jamie Treat
Scott
Building RV-4
